For dual extrusion prints, is there a purge wall option to basically wipe the nozzle. This is required if not, there's pretty much no point doing a dual extrusion print as the two colours will contaminate eachother due to leakage
Thanks
This seems like it can be implemented in the tool head change scripts, you would just have to get the right G-Code coordinates for your printer.dennisjm wrote:Adding objects manually sort of works, but the real magic in the makerbot slicer is the purge wall specific retraction settings. So basically when you're done using nozzle one and switching to nozzle two, you retract nozzle one a whole bunch. Then when ready to use nozzle one again, you purge some additional material into the bucket part of the wall to ensure it's ready to print. It works much better than simply adding manual objects.
I would argue there is very little magic going on in the Makerbot slicer. Adding a wall to be printed isn't something miraculus by anymeans, you could even do this in Simplify3D by adding in per-layer G-code commands in the scripts tab.dennisjm wrote:Adding objects manually sort of works, but the real magic in the makerbot slicer is the purge wall specific retraction settings. So basically when you're done using nozzle one and switching to nozzle two, you retract nozzle one a whole bunch. Then when ready to use nozzle one again, you purge some additional material into the bucket part of the wall to ensure it's ready to print. It works much better than simply adding manual objects.
why not just add retraction && purge to the tool head changes for each process? Shouldn't be too difficult since the purge G-Code is already available in the starting script.dennisjm wrote: This is pretty much why everyone says they still use Makerware for duel prints. I printed this one with S3D because I wanted to customize the supports though. Unfortunate Neither software has all the features.
Hoping S3D comes out with purge walls TOMORROW.
This might be possible but both tools would purge on the same spot since there isn't any way to customize the tool change script depending on which tool your changing to. So you might be able to do something like a variable height purge object and purge in the middle of it but it's just not a very good solution.TenKOhms wrote:why not just add retraction && purge to the tool head changes for each process? Shouldn't be too difficult since the purge G-Code is already available in the starting script.
Well you already have two processes, one per extruder, so you would have two very similar tool change scripts, one per process. The only difference is the extruder being selected would be different, and then you could change the position the tool goes to to purge & wipe, although purge and wiping on the edge of the bed i don't think it would be an issue if they did it at the same edge spot, but if it does, like i said just move it slightly to a slightly different Y position. May seem like a bit of work, but after you get the gcode correct, it's kind of a one time setup and then you'll have it for future dual extrusion prints.dennisjm wrote:This might be possible but both tools would purge on the same spot since there isn't any way to customize the tool change script depending on which tool your changing to. So you might be able to do something like a variable height purge object and purge in the middle of it but it's just not a very good solution.TenKOhms wrote:why not just add retraction && purge to the tool head changes for each process? Shouldn't be too difficult since the purge G-Code is already available in the starting script.
At best I think you could do something like retract the [old_tool] and extract [new_tool] with a bigger amount than your standard retract settings and then add two custom objects with different processes. I haven't tried that. It may come close to a purge wall feature. It's on my list to try actually.
The point is that all that is a pain when instead I could just open up Makerware and export with that instead. Much less work.. unless of course I have an object tha t needs some special support consideration in which case I get motivated to come post here again so that we can get purge walls in S3D soon
