smartavionics
How to really delete a process?
I'm just starting with s3d. It's working OK but I have a really simple problem, deleted processes come back again when I restart the program. So if I delete a process using the button, the process disappears from the Processes list but when I next start the program, any deleted processes are back in the list again! How do I really delete them?
I am using version 2.1.2 for Linux.
Thanks,
Mark
Re: How to really delete a process?
It sounds like your settings aren't saving correctly. Maybe it's a permissions issue? You might want to try deleting the Simplify3D preference files to see if it fixes it
smartavionics
Well, I don't know what's changed but now when I delete processes, they don't come back.
Anyway, thanks for replying.
Cheers,
Mark
dhylands
When you install linux, you use sudo, which makes the installation process run as root.
If (as I did) you make the mistake of choosing to Launch Simplify3D at the end of the installation process, then itt runs as root as well.
I found that ~/.config/Simplify3D and ~/.config/Simplify3D/Creator.conf (and any other files you created during that initial run) were owned by root.
I wound up running the command:
find ~ -uid 0 -print
to see what files were owned by root in my home directory. If all of the files owned by root should be changed you can do:
sudo find ~ -uid 0 -exec chown dhylands.dhylands {} \; -print
(replace dhylands.dhylands with your username.groupname).
smartavionics
Hi Dave,
That's all useful info, thanks.
I can't remember if I started the app from the install dialog or not but I did check the permissions/ownerships of the files it had created and they all looked OK.
Anyway, it's working as expected now.
Cheers,
Mark
habloIngles
That's weird I'm running Xubuntu 14.04, and I don't get this issue, even when running simplify3d straight from the installer
dhylands
Did you try removing/renaming .config/Simplify3D before installing?
habloIngles
dhylands wrote:Did you try removing/renaming .config/Simplify3D before installing?
No, on a fresh install of xubuntu, it just works for me. Run installer as sudo, launch program from installer, quit program, re-open, all settings are intact
