I am using Creator 1.1.2 64 bit . I am using windows 7 64 bit with AMD quad core processor.
We have dicussed in the forum at great length creator stopping in the middle of prints.
See Forum : http://forum.simplify3d.com/viewtopic.php?f=9&t=39
With the 64 bit version it seems to be back in force. Typically any print over 3 hours will fail with my setup.
from reading others posts like http://forum.simplify3d.com/viewtopic.php?f=9&t=125
it seems it is the same problem that existed from the beginning. It has been better with some versions than others or it could just be the parts I am currently making.
I know that I can put it on a sd card and have no issues but that doesnt help find the problems. In the past the problem seemed to be worse with the AMD systems.
I dont want to seem ungreatfull for the software. This product slices like the wind. But the communication seems to be a consistant problem.
I would say the software does a better job of slicing poor models than anything else I have used but I feel you need to make it more clear it will not fix a bad model.
I have uploaded a few models with problems for review not because I need help getting them to print but so you have troubled files to work with for product improvement.
As many of these are thingiverse files the option to redraw is limited. I dont want to take up your time on a specific problem I just want to give meanigfull feed back on problems so they can be resolved in future release.
