Arcadenut
Variable Density Infill horizontally
Wed Jul 11, 2018 7:37 pm
I want to vary the infill of the part horizontally rather than layer by layer.
This would be primarily used for parts that are printed with Flexible materials.
For example, I need to print something like this (attachment):
The areas in RED I would want to be at something like 100% Infill, where as the rest of the part I would only want at say 20% infill.
Right now the whole part needs to be the same Infill %. I want the arms to be able to stretch, but all the areas around the hole I need to be stiff.
I could do separate processes if I cut the model up into multiple pieces, but it would be nice if I could just select parts to vary the infill as I might not know where to adjust the infill until I've printed a few pieces.
TheBum
Re: Variable Density Infill horizontally
Thu Jul 12, 2018 4:23 pm
I know this is a bit tedious, but you can always split the model into multiple meshes and apply a different process to each mesh to control infill. So, it's possible, just not convenient at the moment.
arhi
Thu Jul 12, 2018 5:46 pm
it's tedious and almost impossible with s3d (maybe, just maybe we get the mesh modifiers in s3d in future to solve this) to do with processes but you can use a trick I used to use back when not a single slicer available had the option to vary the infill ... add holes to make your part stronger :D .. tiny tiny holes, it's counter intuitive but works like a charm :D .. what's the biggest hole that's "not printable" on your printer... on most of my printers 1mm hole will be "almost 100% filled".. test on your printer.. 0.5-1mm holes get the job done :) space them according to amount of perimeters you are printing with and the width of your perimeter ... so e.g. if you have 0.5mm perimeter and you print with 2 perimeters space them 2mm apart
look at the example
part (holes are 0.5mm dia, 2mm apart):
slice, 0% infill 2 perimeters ... see, it's almost 100% infill in the area where the holes are:
if you add more perimeters .. e.g. 3 you can make it even stronger
Embed M117 codes into G-Code
open source and unlicence
