Feature: A button that allows user to select only visible models in the "Select Models" dialog under process settings
Implementation: Add "Select Visible" button next to "Select All" and "Select None" in "Select Models" dialog box under process settings
To get here:
1) Open S3D
2) Select a process and click "Edit Process Settings"
3) Click "Select Models" in bottom left corner
4) "Select Models" dialog box opens -- this is where "Select Visible" can be added next to "Select All" and "Select None"
