jmfrank1111
Purge tower infill
Sun Jan 13, 2019 8:58 pm
Hi all,
I've just purchased a Creality CR-X dual extruder printer. It uses one nozzle to print the 2 colors so it uses a purge tower to change colors. As a test, I downloaded and printed the traffic cone. It printed great, but it made a purge tower that is solid PLA the same size as the tower, even though it only changed colors 3 or 4 times during the print. The tower is easily twice as much plastic and the cone. I understand that the purge tower needs to be the same height as the printed piece s the nozzle can purge on to something (so it's not trying to print into thin air) but is there anyway to make the purge tower only print a 10% infill when the nozzle isn't actually purging?
Thanks,
Joe Frank
Albaxwad
Re: Purge tower infill
Tue Feb 05, 2019 11:51 am
Like you, I have recently got the CR-X and was surprised at the amount of filament used for purging. I did get some advice to ignore the tower and use ooze shield option instead. So, as I type this, I am doing the first print of the vase model using the shield. It looks messy but so far so good. Try it.
manueloya
Wed Feb 06, 2019 2:51 am
hi
And it would be interesnate to allow to reduce the number of pillars as the impression is ending in those colors.
When I have a single color to print in the end of the print , I generate a process and I disable the pillars and the printer stops spend more material for pillars , should allow to disable pillars at the end of using their color definitely
