Re: Dense Infill to support Top Solid Layers
Tue Aug 27, 2019 11:51 am
wirlybird wrote:
Tue Aug 27, 2019 11:44 am
Now, if the feature for a dense layer adds items such as-
path direction/angle so you could set a unique angle and not just default to the solid infill angle.
Speed
Extrusion width
bounding perimeter(s)
expand past default size like in bridging.
Things like this might make it an actual functional feature rather than just another way to do what can already be done easily.
Some thoughts.
Great ideas being added! I love it. I'll be adding these to my documentation of this feature request for our development team to review.
Thanks everyone!
Overheal
Wed Aug 28, 2019 10:28 am
Silly question, but why can't you model a hollow cavity under the problem area? Eg. see my attachment below, in Fig. 20 I added a hollow slot inside the solid model I was printing, forcing support material where I needed it to be in an otherwise empty/low-fill portion of the print.
You can use variable settings wizard already to ramp up the density for the few layers preceding a large top floor; but if the feature is only a small portion of the model, that might be wasteful.. would it be more wasteful then what I did?? Debatable! :P
rexipus
Wed Sep 11, 2019 6:21 pm
So far it was all just words, and I wanted to demonstrate this, so I ran a test. Test consisted of a 50x50mm cube printed 5mm tall. I printed it with two perimeters. I duplicated it, and set up different processes so I could test two of these cubes side by side during the same print.
All layers were .2mm high.
Test 1:
one cube printed with 10% infill, 4 top layers
one cube printed with 10% infill, 3 layers of 30% infill, 4 top layers
Test 2:
Same as above but 5 top layers for both cubes
Test 3:
Same as above but 6 top layers for both cubes
Looking closely at the test cubes, I'd estimate that the ones where I added three 30% infill layers before the top were about two full top layers ahead of the cubes where I just printed top layers over 10% infill as far as establishing a good, solid top layer with little to no trace of underlying infill. Had I gone with a 40% infill for three layers instead of 30%, it would have been more dramatic a difference. I may run another test and just print the same cube with three layers of 40% over the 10% main infill and four top layers just to see how it comes out. Due to lighting and using a cell phone to take these photos, the effect can be somewhat exaggerated in the photo, but even at four top layers, the cube with the 30% infill before the top has the underlying infill texture very visibly yet in terms of the actual surface texture, it's very faint differences in the surface, whereas the cube where the four tops printed over 10% infill the centers of those cubes where the infill is are far more undulating and bigger actual surface differences.
This was all done in PLA. If I'd used PETG the differences would have been far more dramatic, since bridging of the top layers over the infill would have taken an extra two or three layers to firm up.
tookys
Thu Oct 24, 2019 8:46 am
I use simplify to handle a large format printer at work (1000mmx1000mmx500mm).
A common issue i have is that if i try to set the infill low (5%) when it tries to do a pocket or top feature it will end up printing away from any infill causing the feature to fail or not form properly.
And even when i set it higher (30%) it will still have issues near the edge of the feature. even after 5 layers of top fill.
My idea is to make it so that when simplify plans out the first layer of a top fill it plans to continue the edges out to the next support structure. After the first layer it will do any additional layers normally. But giving the first layer an anchor point at each end would help make sure it forms properly.
Attached are some pictures of what i think these first layers would look like.
Fri Oct 25, 2019 2:36 pm
I moved this here as its very similar. Thanks for the screenshots. I think it is great to have another way to look at this problem.
