presently - flow travels w/ material type. same w/ bed temp and hot end temp. awesome stuff really.
cooling also seems to travel.
however, it's been my observation that filament density however - does not travel with saved material type.
I'm sure there are other settings which may travel and may not travel with filament type(s).
it would be greatly appreciated to be able to have this travel w/ the filament type.
same w/ coasting and wipe. as wipe makes for a great ooze control option when printing pets.. but I don't need it on abs or pla.
ASA.. definitely has a different density than pla. hatchbox pla is 1.25, where as formfutura Apollox ASA is 1.11.. and if you fail to catch the density change.. your flow multiplier isn't correct. etc etc etc..
