arganaz
Use "Raft" Like code on top and bottom layers
Fri Oct 25, 2019 4:10 am
As the title states, please add an option to use "Raft" Like code on top and bottom layers
It would allow us a better print and you wouldn't need to use "ironing".
Thank you,
Paulo
DarthRevan
Re: Use "Raft" Like code on top and bottom layers
Fri Oct 25, 2019 2:01 pm
For simple flat surfaces which have a decent amount of infill below them this could work well.
Rafts are heavily extruded and therefore would likely introduce accuracy issues with any complex edges.
I can't imagine the horrors of attempting to dial in the tolerances on some tight corners with raft type extrusion settings.
