arhi
tag objects being printed
Wed Mar 25, 2020 9:33 am
New G-Code is introduced that is supposed to be used by slicers to tag objects on the plate so that during print any object can be canceled (instead of whole print plate). So far Marlin is supporting this and RepRapFirmware released beta today with support for M486. It is something Simplify3D should support as soon as possible.
https://reprap.org/wiki/G-code#M486:_Cancel_Object
The M486 G-code provides an interface to identify objects on the print bed and cancel them. Basic usage: Use M486 T to tell the firmware how many objects there are, so it can provide an LCD interface. (Otherwise the firmware counts them up in the first layer.) In every layer of your G-code, you must preface each object's layer slice with M486 S[index] to indicate which object is being printed. The index should be zero-based. To cancel the first object, use M486 P0; to cancel the 5th object use M486 P4; and so on. The "current" object is canceled with M486 C.
G-codes associated with the canceled objects are no longer printed. Firmware supports this feature by ignoring G0-G3/G5 moves in XYZ while updating F and keeping the E coordinate up-to-date without extruding.
Slicers should number purge towers and other global features with a negative index (or other flag) to distinguish them from regular print objects, since it is important to preserve color changes, purge towers, and brims.
Host software (such as OctoPrint) may be able to cancel individual objects through a plugin, and in this case they should not use M486 P to cancel objects (although doing so should cause no harm).
Embed M117 codes into G-Code
open source and unlicence
Re: tag objects being printed
Wed Mar 25, 2020 9:53 am
Thanks for sharing this! I had not seen this go into stable Marlin. I'll be interested to see what other users think about this.
arhi
Wed Mar 25, 2020 4:29 pm
Yup, Marlin pushed it GA and RepRapFirmware pushed yesterday first beta ... supporting this is going to be fairly important feature for all slicers
