rb1205
Re: Reload Part
Mon Mar 07, 2016 4:51 am
Repetier Host has this as well (autoreloading updated parts) and it's a godsend. Please add this.
controlsfreek
Re: Reload Part
Wed Mar 09, 2016 5:50 pm
+1! I also just switched from RepetierHost to Simplify3D- this is a much-used feature that is missing!
avluis
Re: Reload Part
Sat Mar 26, 2016 4:36 pm
+1
supinemonkey
Re: Reload Part
Mon Apr 18, 2016 2:41 pm
Still no progress on the reload button? Wow it would be useful. Really really useful, sooner the better. Seems pretty simple to incorporate but wow the convenience it would add for designers. Whew.
jmunkki
Re: Reload Part
Sun Aug 14, 2016 4:05 am
Thumbs up for this. Just a menu item to reload all selected models from files without changing scaling, position or rotation would speed up my workflow immensely. In some cases, I might even want to keep the same support structures.
zapta
Re: Reload Part
Sun Aug 14, 2016 12:11 pm
+1
Nugh said.
saintgimp
Re: Reload Part
Mon Sep 12, 2016 4:06 pm
I very much want this feature, too. It seems like it would be pretty simple to implement and it would be a huge help for iterating between my CAD software and Simplify3D. Right now the workflow is particularly obnoxious because the default coordinate system in Fusion3D is rotated -90 degrees on the X axis compared to the coordinate system in S3D, so when I tweak my model not only do I have to remove the model from S3D and re-add it, but I also need to rotate it every time in S3D so it lays flat. There absolutely should be a "reload" option that will simply get the new STL from disk and update the model in-place.
junktronix
Re: Reload Part
Mon Sep 12, 2016 9:52 pm
+1 as well. This would really speed up my design process
HexHyte
Re: Reload Part
Tue Sep 13, 2016 2:58 am
+1!!
Gnevko
Re: Reload Part
Wed Sep 14, 2016 12:55 am
+1
