lith74
Option to auto-generate supports under the entire model
Mon Feb 22, 2021 12:02 am
I have many prints that I print on a raft where only a small part is touching the bed/raft. Many of these have intricate designs and I spend a lot of time manually adding all of these supports. Changing the support angle down to 1 degree does not add the needed supports, in fact it doesn't add many more supports than it being set at 45 degrees.
