Please add Qidi Tech I-Fast Configuration in the supported printers list.
Posted: Mon Aug 16, 2021 11:27 am
by michaelsloan
Hello I have a bunch of printers and my newest one is a Qidi Tech I-Fast I would love to see this printer added into the supported printers list so It can be automatically added to the software easily so I don't have to switch between printers each time and set it up every time I use it.
Thank you so much
Re: Please add Qidi Tech I-Fast Configuration in the supported printers list.
Posted: Thu Aug 19, 2021 6:05 pm
by parallyze
michaelsloan wrote: ↑Mon Aug 16, 2021 11:27 am
...so It can be automatically added to the software easily so I don't have to switch between printers each time and set it up every time I use it.
are you using the configuration assistant to switch between different printers? If so you might want to have a closer look
at the "Update Machine Definition" option in the process settings (FFF settings -> G-Code). That way you can switch print bed
size/firmware configuration when switching profiles.
Posted: Fri Oct 01, 2021 9:18 pm
by wirlybird
Thank you so much
Have you sent an email to QIDI and asked if they have a profile?
They made profiles for other QIDI printers and usually supply it on the USB that comes with the printer.
Posted: Sat Oct 02, 2021 8:39 am
by wirlybird
I've asked a couple people and they say there is a profile on the USB drive that came with the printer.
