carlomacchiavello
two feature request about bulldog grip and order of edge bui
Hi guys,
i have two feature request :
i think could be useful if i can setup in a software the position of bulldog grip that i use to lock glass on heated bed, to avoid IT in g-code path.
more important feature request.
ability to force inner to outer path for some kind of obj
if path start from inner edge to outer edge it avoid to build support, but if start to outer edge, it need support.
Umpa
Re: two feature request about bulldog grip and order of edge
I had the same bull dog clip problem, solved by sticking the glass down with thermal conducting pads - no clips no problem, glass secure & can be removed in required. This is the best all round option IMO.
