drmaestro77
Re: Improvement Request: Generate Raft only under supported
Sat Apr 04, 2015 2:22 pm
+1 Supports can be very hard to stick to the bed especially if they are isolated. There should be an option to draw a raft only under the supports and not under the object itself if it already has a large flat bottom.
Yona.Appletree
Fri Apr 10, 2015 8:07 pm
+1 Makerware does this correctly, and it doesn't seem that hard.
Vasily
Contact: ICQ
Mon Apr 20, 2015 8:54 am
+1
Wanhao Duplicator 4X DH
mitchfx
Mon Apr 20, 2015 9:44 pm
Yep, there have been many times I've wanted the same thing. Actually I'd say I want this more often than raft under the model.
Hans128
Mon Sep 07, 2015 7:49 am
+1
I have the same problem. Please add the feature !!! I only need the raft under the support area.
Tetraodon
Sun Sep 13, 2015 3:35 am
+1 :)
I also noticed that even with separate processes for different objects, if one object was printed with a raft, all had to be? Which admittedly was a pain for trying to print multiple objects (when only one needed a raft, for example)
Hans128
Mon Oct 12, 2015 10:23 am
+1
Please adds this feature !!!
Marshall
Thu Oct 15, 2015 3:54 pm
+1 But, consider the following...
My request is similar, though in my situation, I need a raft only under the bed contact portion of the part, and not necessarily the supports, and the raft needs to take into account INSIDE part perimeter, not just the outside perimeter. Since we are talking time and excess, it is of equal importance I feel to address this.
I continuously print hold-down plates for various heat-sinks...well the use is not important anyways. But the plates more or less are the equivalent to a picture frame in shape. It's also a shape which likes to bow if not stuck firmly to the bed. The raft feature however, you could say, is printing the entire "picture" inside of the "frame", when all I need is to raft support the frame itself with raft exterior overhang calculated on the interior perimeter as the exterior perimeter. It definitely is eating much excess filament and time which has made me hesitant to even use rafts when making these. Thus, I'm cutting corners by creating attached skirts not to use the heavily excess rafting. Skirts give me outside sanding work in this scenario, but a raft will pull off and not effect the exterior look of said hold-down plates since bottom cosmetic is not important. That is my justification for desiring this feature. Please consider both circumstances at play. :D
