greybeard
Re: Ability to measure STLs, hole sizes, and bottom surface
Thu Aug 15, 2019 4:42 pm
I wrote an App to measure Any graphic for which only one dimension is known. The graphic can be an STL
The primary purpose at the time was to measure electronic parts but, it works for any graphic or 'whatever' on your monitor.
Example of using it in Simplify, below... CLICK on the video to open/view it
• Loaded the .STL into Simplify
• I know the width of the Part (see drawing image)
• Though also knowing the Dia of the large hole, the attached video shows using the App to confirm the Dia...
(I did not fuss with trying to get an exact dimension...)
The app is written in Java and requires Java8 (JRE 1.8) as minimum.
The app with use info is posted here
https://github.com/farTooOld/Woof
3D Print Parts
lazymaniac
Wed May 13, 2020 4:05 pm
+1 Measure tool could be really helpful :)
Thu May 14, 2020 11:50 am
Thanks for your input. We'll keep monitoring this thread for valuable user feedback!
arhi
Thu May 14, 2020 12:16 pm
Free version of netfabb is awesome for measuring features on the mesh. Having that functionality inside S3D would be useful, not a priority really as so many mesh tools already have it, many other things lacking in s3d that are much more important and much more related to actual slicing.
Embed M117 codes into G-Code
open source and unlicence
CaesarDGreat
Thu May 21, 2020 12:48 am
Please add a measurement feature
kingmokex86
Mon Jun 15, 2020 1:19 pm
Yes this would be a very useful feature to add!
parallyze
Fri Jun 19, 2020 11:20 am
...not a priority really as so many mesh tools already have it, many other things lacking in s3d that are much more important and much more related to actual slicing.
+1
Actually I'm still trying to figure out _IF_ I ever missed a measure tool inside S3D. I mean... it shows the objects size, so conversion mm/inches is usually no problem.... any real world usage example for this, why would I need to measure a hole inside an object inside the slicer?
boatanchors
Tue Jul 07, 2020 1:23 pm
+1 for me, too. Thanks!
