Wed Feb 11, 2015 1:38 am
Using different processes do help in this regard but then the whole section of the model need to be printed that way slowing things down. Also using different processes one need to find & define the ranges manually. The interfaces between layers also tend to be printed with 100% infill (or one might get areas without infill where you wanted it).
I sometimes create the zones with overlap & then go in and delete the overlap area manually - a bit tedious if you have a lot of these zones with overhang.
