lmig
Re: Ability to Interact with Print Server APIs
Mon Oct 26, 2015 3:18 pm
Still I have to save the gcode file to a specific folder/path. depending on the last used folder I still have to navigate to the network share.
A button, "send to octoprint", just like Slic3r already has, would be simply awesome.
K. Hendrik
Fri Oct 30, 2015 8:19 pm
I would also like to see a print via octoprint feature.
didymus
Wed Nov 18, 2015 5:33 am
+1 for me too.
I think a lot of people are using Octoprint to manage their printer connection, this would be a great addition IMO.
maddavo
Sat Nov 28, 2015 6:43 am
+1 for this.
I run RepetierServer and it's great.
Copying g-code jobs to the printer is not just what a server is about. I need to be able to control the printer remotely from an App interface. I'm disappointed Simplify3D cannot do this - RepetierHost can.
procivitasvxo
Tue Dec 08, 2015 2:58 am
+1 on this one. We're also using octoprint and it would be really nice to be able to use simplify3d more seamless with it!
Gadroc
Sun Jan 31, 2016 8:45 am
+1
The machine control panel should have an ability to point to a octoprint server as the port and click connect. Then if everything else worked the same that would be awesome.
jemarvin
Tue Feb 02, 2016 12:33 pm
+1 For this. Just started using Octoprint this weekend. I'd love to send STL to OctoPrint (possibly from a mobile device?) and use S3D for Slicing.
foosel
Thu Feb 11, 2016 12:55 pm
Hi, developer of OctoPrint chiming in here. I'm using S3D myself and would be happy to support any development going into this direction.
pgoth
Fri Mar 04, 2016 2:21 am
I've added just a small command to do this in the script section. See viewtopic.php?f=23&t=1924&start=10#p20335
avluis
Fri Mar 25, 2016 1:01 pm
If you guys end up supporting this, which is highly needed btw, please support the API itself as I am using Astroprint (they use OctoPrint as well for their backend), and while they started exposing a bit more of it, all I am given is the API key, which should be all I need really.
Anyways, support OctoPrint, via API!
+1
