Copying g-code jobs to the printer is not just what a server is about. I need to be able to control the printer remotely from an App interface. I'm disappointed Simplify3D cannot do this - RepetierHost can.
The machine control panel should have an ability to point to a octoprint server as the port and click connect. Then if everything else worked the same that would be awesome.
If you guys end up supporting this, which is highly needed btw, please support the API itself as I am using Astroprint (they use OctoPrint as well for their backend), and while they started exposing a bit more of it, all I am given is the API key, which should be all I need really.
