kjhuebner
[ADDED] Need Speeds greater than 100 percent
Sun Apr 12, 2015 8:23 pm
When editing the settings -- on the "Other" tab -- various speeds can be set.
However, I cannot increase many of the speeds above 100 percent. Namely...
Outline Underspeed
Solid Infill Underspeed
Support Structure Underspeed
I want to increase the support structure speed to 110% but I cannot. 100% is the limit. Why?
A user should be able to speed up and slow down every type of operation (outline, infill, support structure, whatever! etc.).
This would give maximum versatility in creating fast, quality prints.
I tried a workaround of boosting the default print speed, then adjusting the underspeeds. This does not work as it throws off other portions of critical print speeds.
Ken Huebner
Product Developer
Vasily
Contact: ICQ
Re: Need Speeds greater than 100 percent
Mon Apr 20, 2015 8:50 am
+1
i think can be 500% for some prints
Example:
material: flex
regular speed: 30 mm/s
support speed can be: 50-90 mm/s (~160..300% from regular)
Wanhao Duplicator 4X DH
kjhuebner
Tue Apr 21, 2015 9:39 am
But you're using absolute speeds (e.g., 30 mm/sec). Seems to me the percentage approach (e.g., 110%) should be supported as well, since it's more versatile.
JWS
Sun Apr 26, 2015 5:13 pm
+1
Fri Jul 10, 2015 6:28 am
This has been changed in version 3.0. You can now enter values greater than 100% for those options if you choose.
