bone
Raft located just for support material
Fri Jun 26, 2015 9:45 am
I would like to see an option for printing raft for just were the support material touches the bed. I found using a raft helps with getting the support material to not warp with ABS or not break off the bed when it gets tall and thin.
mitchfx
Re: Raft located just for support material
Thu Jul 02, 2015 1:11 am
Yes! +1
This would be super useful.
Menissalt
Fri Jul 03, 2015 6:01 am
I agree. I have a heated glass bed and most things stick very well (very smoothly) once i use a brim but supports are proving (very) difficult. If we could just have the first couple of layers solid it would be a big help!
bone
Tue Jul 07, 2015 12:51 pm
Menissalt wrote:I agree. I have a heated glass bed and most things stick very well (very smoothly) once i use a brim but supports are proving (very) difficult. If we could just have the first couple of layers solid it would be a big help!
You can already do that by adding a raft, which prints a solid layer (depending on settings) under the part and support material. The problem I have with that is that I dont want the added layer of raft material sticking to the part and I only need where raft where the support material touches the bed.
I use a large skirt, that can trimmed off later, to hold the part to the bed.
