Solid angle
Posted: Mon Oct 05, 2015 6:02 am
by tee_nalle
Hi.
When I use multiple processes for a print and the first process is one layer thick then the two bottom layers have the same angle on the solid bottom. Witch make it a little more fragile than it should be.
A natural thing would be that the program used the same angles that I have specified in "Infill".
Regards Tomas Wallentinus
Re: Solid angle
Posted: Mon Oct 05, 2015 10:52 am
by bapro
The softwaer starts at the angel you specified. If your settings are 45 and -45, you have to make it -45 and 45 for your other process.
Re: Solid angle
Posted: Mon Oct 05, 2015 5:00 pm
by tee_nalle
HI.
Doesn't work on my setup. On the first process only printing the first layer the infill angles are 45 and -45. On the second process that is used fore layer two and up they are -45 and 45. But in the print preview I can see that its the same angle on both layers.
Re: Solid angle
Posted: Tue Oct 06, 2015 10:33 am
by bapro
Ok, I see that now.
It wasn´t like that before as I remember.
Must be a bug.
