BA1
Feature Request: Start/Stop at LAYER
Thu Dec 17, 2015 11:47 am
Although there is a feature to start/stop printing at a mm height, I often need to change settings at a particular layer. It is time consuming to carefully determine the height of the relevant layer.
Could you add a toggle to the "start/stop printing height" so a user can select a layer number or a height depending on what they are trying to accomplish.
Re: Feature Request: Start/Stop at LAYER
Mon Mar 21, 2016 4:11 am
The only problem with specifying layer numbers for heights at which to start or stop printing is where for example you're printing at a layer height of 0.2mm for the lower part of the print and 0.3 mm for the upper part of the print, then you have to do a bit of mathematics to work out the number of the start layer for the upper part.
