Page 1 of 3
Adjust print speed for overhangs
Posted: Thu Mar 10, 2016 2:08 am
by adge
I've found that slowing the print speed right down produces the best overhang results, however printing the entire print or relevant layers at such a slow speed is pretty inefficient. By creating a setting that would allow users to adjust the print speed depending on the overhang amount would greatly improve print quality.
Most of the community uses additional cooling fans to overcome overhang curling or sag, but this seems unnecessary when this setting could solve this.
The software would detect the overhang amount for each section of every layer, and when the overhang exceeds X amount, it would slow the print for that particular section of the layer and then continue at it's original speed after the overhang is printed.
Re: Adjust print speed for overhangs
Posted: Mon Mar 14, 2016 8:43 pm
by kejocu
Excellent idea!
Posted: Tue Mar 15, 2016 11:20 am
by Zapperke
+1
Would be great!
Posted: Tue Mar 15, 2016 2:29 pm
by NitroXpress
Would be perfect !
Posted: Sun Mar 20, 2016 3:19 am
by KC_703
Good idea.
As a workaround for the time being, use multiple print processes to adjust print settings for any given section. So for the section with the overhang, use a process with a slower print speed. Then add a second process with normal print speeds... its meticulous, but should work.
See this write-up:
https://www.simplify3d.com/support/tuto ... f-a-model/
VIdeo tutorial:
https://www.youtube.com/watch?v=EbQfifnzL4Q
Posted: Tue Aug 30, 2016 3:44 pm
by Xtroodler
Googled this today and found this topic. Disappointed to find this isn't a standard thing already. Definitely got to give this a +1.
Posted: Fri Sep 02, 2016 8:21 am
by TMeyer
+1
Posted: Sat Dec 17, 2016 3:07 pm
by delta440
+1
Posted: Tue May 09, 2017 12:02 am
by timmah1991
Xtroodler wrote:Googled this today and found this topic. Disappointed to find this isn't a standard thing already. Definitely got to give this a +1.
Same and same. Get on it, S3D.
Posted: Thu May 11, 2017 4:12 am
by ViperZ
Hi
How is the judgment condition in the figure below?
