maker2
start point - relative to model
Sat Apr 23, 2016 6:55 am
Manually setting a start point is great for placing seams "out of sight".
But what happens if you want to print multiple copies of that model?
It would be great if there were a solution to that!
zemlin
Re: start point - relative to model
Mon Apr 25, 2016 7:12 am
I set my start point based on X and Y coordinates off the plate.
My M2 has a 250 span on the Y axis, so if I want all my 'parting lines' to be at 9:00 on the parts I set the start point at -9999, 125.
10 meters out on the X-Axis makes it essentially identical on all parts on the build platform.
armsofilum
Fri Jan 25, 2019 10:09 am
I'm going to bump this up because I think it is an underappreciated request that could save people quite a lot of time.
I've recently come to S3D after being a Cura user for over 2 years and one of the features I miss from that application is the ability to set the Z-seam relative to each model. The suggestion by zemlin is a good one, but it doesn't help with complex models where the seam can be hidden in a less visible, inner portion of the piece.
This, and the ability to prioritize corners (either convex or concave), would vastly enhance what is already a great application and would give users much finer control over the seam placement without forcing separate processes for every piece on the build plate.
Thu Jan 31, 2019 2:12 pm
This is quite an old thread, but I appreciate your added feedback. I'll track this thread to gauge additional user interest!
tonyno
Thu Jan 31, 2019 3:30 pm
Necro! I have often wanted to pick a point on a/each model versus a bed location.
