There are times that I have a need for supports in several directions.
One example is a part that has holes at several different orientations. There is no way to choose a single support direction that will lay material perpendicular to each different hole.
If we could add different manual support regions on each part it would give better control. Adding new regions would provide the ability of supports at different angles in different locations on the same layer.
