LC57
Dual extruders build statistics
Sat Jun 11, 2016 4:40 am
Currently, build statistics only show global data, like if printer have only one extruder.
I have a 2 extruders printer, and when using both of them, I would like to have statistics for both extruders in complement of global data.
BSVENT
Re: Dual extruders build statistics
Fri May 24, 2019 9:09 am
Is this future already covered in version 4.1?
Tue May 28, 2019 3:05 pm
You can already include the individual extruder statistics in your output file using post processing commands and the existing variables.
Try inserting the following variables in the post processing section of the scripts tab using the PREPREND command and you will notice these stats appear in the beginning of the gcode
{PREPEND "; total filament wg = [total_filament_weight]\n; T0 filament wg = [extruder0_filament_weight]\n; T1 filament wg = [extruder1_filament_weight]\n; total filament cost = [total_filament_cost]\n; T0 filament cost = [extruder0_filament_cost]\n; T1 filament cost = [extruder1_filament_cost]\n; total filament used = [total_filament_used]\n; T0 filament used = [extruder0_filament_used]\n; T1 filament used = [extruder1_filament_used]\n"}
More on the scripts tab can be found here
As always, I've documented your interest in this being improved inside the GUI and look forward to monitoring this topic for more ideas from all interested users.
Thanks for your great feedback!
