with Simplify3D (V3.1) I started a new print which has some support.
The objects has a height of around 10 cm.
The first 20mm the print worked well. But above 20mm the support come loose and did not stick to the printbed anymore.
As you can see in the image below the support structure is printed directly on the printbed without any brim. Only the object has got a brim.
Since the support paths are very thin lines (only one nozzle width) it does not stick to the printbed very well.
And if the support has a certain height the leverage effect takes place and makes the support come loose.
I believe if S3D would create a brim for the support structure as well then this would not happen.
So please add an option to enable 'Brim for support' with settings like:
'Support brim extruder'
'Support brim layers'
'Support brim outlines'
Thanks a lot!
