I like Vase Mode. And yet, I find it to be quite restrictive. I'd request that the various settings that constitute Vase Mode today be broken out into individually addressable process settings. The following is a list of the various settings that I've identified as being affected by Vase Mode. There may be others. But I'd request these changes in process configuration settings and setting up of multi-process jobs...
- I want S3D to always honor the Perimeter Shell Count. An XY plane will bisect vertical protrusion of a manifold mesh twice. So even a protrusion having a thickness of just twice Extrusion Width will be 2 shells thick. (Yet shapes thinner than the thickness of 2 shells aren't currently rendered. Grr!) Vase Mode always generates just 1 shell. I think it does so because it only follows the exterior mesh of the geometry. Vase Mode does this even when the imported mesh isn't manifold. It completely ignores anything beyond the exterior.
- The Slicing Behavior section of the Advanced tab should have a third option for how to handle non-manifold segments. This third option would configure S3D to not special-case non-manifold segments. When this option is chosen, non-manifold segments should be rendered with the specified number of top, bottom and perimeter shells -- and obviously no infill. I believe that this should actually be the default option.
- S3D should honor the non-layered nature that is currently only possible in vase mode, but also do so when printing a non-manifold segment with only 1 shell.
- S3D should allow the generation of jobs that contain multiple processes even when 1 or more of the processes are Vase Mode. The restriction necessary for Vase Mode processes to coexist in jobs like this is simply that a Vase Mode process be the only process that adds gcode in a Vase Mode's vertical volume. For example, a non-vase process may be defined to print a base in the lower layers of a job. A vase process may then start above the base geometry. Finally, the job may end with a third process that prints a lid or a rim just above the space where the vase process stops. Another interesting example might be a job that consists of multiple Vase Mode processes but that use different extruders -- thus enabling the printing of multi-color and multi-material vases.
- Bob
