Outermost Layer Fill Settings
Posted: Fri Mar 31, 2017 5:50 pm
I'd like to see independent control of the Outermost upper/lower shell fill pattern
*Concentric looks great, but leaves huge gaps relative to other slicers.
*Fill patterns line up, so you can see light through the bottom of even large models with many top/bottom layers
By letting the inner top/bottom layers use linear fill, we're a LOT less likely to get failed bridges (my benchies look awesome in other slicers, but have droopy roof in S3D), make for solid looking parts, and still retains the detailed look of the concentric outer pattern.
I can post pics if needed. Thanks!
