RogerWilco486
Re: Request: Firmware Retraction
Mon Jan 07, 2019 11:00 am
OP here, still waiting for this feature.
Eddiie
Fri Jan 11, 2019 12:17 pm
+100 for a checkbox that does the search/replace behind the scenes.
Why is this so difficult to add this?
alexspeller
Wed Jan 23, 2019 5:56 pm
I found, at least on the latest version, that the M101/102/103 generated more retracts than would otherwise be the case.
I fixed this by using some bogus retraction settings and replacing that instead, e.g. 0.1mm at 6666mm/min. Make sure not to set Z hop as that will come out as a separate move.
Then I replaced the actual retraction gcodes with this script:
{REPLACE "G1 E-0.1000 F6666" "G10"}
{REPLACE "G1 E0.1000 F6666" "G11"}
This resulted in 25% less G10 calls in a sample test print, which came out looking better for it.
smoki3
Wed Feb 13, 2019 3:41 am
1+
Would be great if they can support this
Wallabear
Wed Feb 13, 2019 4:44 pm
I would really, really, REALLY like to see this feature add as well
dwallersv
Sat Jun 01, 2019 10:40 am
Another vote for a firmware retraction option.
The problem with post-processing substitution
Can't use wiping and coasting features. With these enabled, the retraction is not always contained in a single extrusion G1 with the set filament length and feedrate. It often (most of the time) will be split among more than one G1 line, with the retraction distance split between them. These are the coasting and wiping moves.
So while the unretracts can be found easily (say, 1mm 20mm/s search for and replace "G1 E1.0000 F1200" with "G11"). You'll find there are very few matching "G1 E-1.0000 F1200" lines, but a ton of things like "G1 E-1.6667 F1200" a few lines back, combining a retract with a coast/wipe. Problem is, the retraction amount is not always the same.
Haven't tried the M101/2/3 approach -- will try it today. However, I'm curious as to how that will interact with coasting and wiping -- could end up with insufficient extrusion after extraction (G11 won't account for extra retract from coasting). Maybe it doesn't matter.
Leary
Mon Jun 03, 2019 9:51 am
+1 Please add support for FW retraction
maker2
Thu Jun 06, 2019 12:55 pm
+1 from me (and +several from my friends)
doing it with scripts is messy because you have to modify every single profile which inevitably leads to errors.
But Firmware Retraction is wonderful and is there really any other way to dial your hotend/filament combination in?
th0mpy
Sun Jun 09, 2019 10:00 am
+1 for me too. I thought this would be kind of a standard thing.
jonasholmberg
Tue Jan 21, 2020 10:05 am
+1 on this request.
I use M209 (auto FW retract) on my Marlin printers, which work great, but I need this for my Reprap printers aswell.
I really think an easy function like this shouldn't take years (reading this thread) to implement in a commersial product like this.
