Implement an optional fix for under size holes
Posted: Thu Aug 10, 2017 10:57 pm
by Rhino_Aus
I need to print technical parts that need to have properly sized holes in them, often in locations that can't be drilled after the fact. It seems to be a well known issue with 3D printing that small holes are too small and it is bizarre to think that an "Arc Compensation factor" has not been added to S3D to allow you to account for that. The solution is easily described by the differing path length around a radius and a arc correction factor would be very powerful to solve this issue.
Re: Implement an optional fix for under size holes
Posted: Fri Aug 11, 2017 9:19 am
by tsinus
dito - same is also my problem and wish for future update.
