So, when i have an object and I have 1 complete process configured with my extruders and layer height and stuff. When i add a new process2 it copies all the values from process1.
you said:
In Simplify you can change the first layer thickness (only up to 199%, which is not really enough if I am doing 0.1mm layers and want the first one to be 0.3mm)
in process2 which we just added, you should be able to configure layer height to .3 @ 100% for first layer height, and also control the "width" of these in the "extruder" tab.
unless i am missing something?
