1. Please offer the option for the Brim Pillar to print on every layer for all extruders before the layer starts printing. It is not printing for both extruder # 1 and extruder # 2 on every layer in a dual extruder setup. Perhaps the option to make a separate pillar for each extruder or half layers for each extruder when both are used on the same layer would do the trick.
2. Please offer the option to print the Skirt on every layer where an extruder is used before the layer starts printing. It is not printing for both extruder # 1 and extruder # 2 on every layer where both extruders are used in a dual extruder setup. Perhaps the option to make a separate skirt for each extruder or better yet kissing the previous extruder's loop just enough to make the new extruder's loop stick to it would do the trick.
3. Please offer the option to print the Ooze shield on every layer for all extruders before the layer starts printing. It is not printing for both extruder # 1 and extruder # 2 on every layer where both extruders are used in a dual extruder setup. Perhaps the option to make a separate Ooze shield for each extruder or better yet kissing the previous extruder's loop just enough to make the new extruder's loop stick to it would do the trick.
Edit: Skirts do print on every layer for a dual extruder setup, but they don't print in the correct order...see my post below.
