More Speed Options
Posted: Thu Nov 09, 2017 9:56 pm
For advanced users, we need more speed options.
Speed options for:
Small perimeters/features
For those small bosses and holes. They always turn out blob of material.
Dense support
I use PVA for dense support and ABS for normal support structure and part. PVA needs to be laid slowly for good adhesion on top of ABS but there is only one speed option for the support.
So I always end up printing the rest of the support structure really slow….
Gap Fill
When filling small gaps, the printing head uses small zigzag movement which results in enormous shaking and resonance issues.
Others
Unit of speed options for both mm/s or %.
% works okay but sometimes you want a specific value for specific printing feature. We can all calculate the % in the end but it will be easy for the slicer to understand both.
Move all speed options in to the “Speeds” panel section.
At the moment, the speed control is all over the place and they actually override the speed if you are not careful. “First Layer Speed”, “Bridging Speed Multiplier”, “Tool Change retraction speed”…
Change the wording of “Default Printing Speed”
I figured that the “Default Printing Speed” really just means “Infill Speed” (not including top/bottom solid layer). This should change the name to “Infill Speed”.
Speed options for:
Dense support
Gap Fill
Others
