Having a read on a forum someone came up with an interesting concept.
Printing from the outside inwards why cant we set the first layer of the shell to be say 0.1mm and do two passes then for the rest of the inner layer do them at 0.2. this would create a high definition surface and allow you to still print the rest of the item fast.
The setting could be done as a division of your internal layers. say if you set your internal layer to 0.1 then your shell layer would be 0.05 etc..
Im sure with some creativity you could even graduate the passes from the outside inwards with the say the first pass of the shell being 0.05 and built up 2 layers, then the next being 0.1 and build up 1 layer, then go back to the shell and built up another 2 0.05 layers and in to the next pass of the shell and build up another 0.1layer then the rest to the center at 0.2...
Doing it this way would create a huge amount of detail on the outside.
