timmit99
Solid Support every "x" Layers
Tue Dec 12, 2017 10:11 am
With my machine i can print at 100 mm/s however support material towers wobble at these speeds. If i change the settings such that there are multiple process' and that every 10 mm (10->10.2, 20->20.2...) it prints support with 100% infill. This solidifies the support towers and keeps them attached together.
If there was an option to have the supports print a solid layer every x layers that would be great ( Like the "Include solid diaphragm every "x" layers for the infill)
brian442
Re: Solid Support every "x" Layers
Tue Dec 12, 2017 12:43 pm
You could try setting the support angles to 0 and 90 degrees (instead of the 0 degree only default). That will print a criss-cross pattern that seems to help for some of the taller prints I have done.
