Well, I have been using this software for just a week and was still doubting if I was going to keep it since it costs the same as my Monoprice Select Mini... But, when I found you can use different processes in the same piece and you can save everything in a simple project file (factory file), I fell in love with it and decided to keep it.
I only wish you had some kind of configuration/profiles sync service because I use to design in more than one machine and that would simplify my life even more...
I also wish you could add more top layer patterns because, sometimes, texture is also important.
Since I'm already here, I'll add that it would be awesome if you could set the different processes depending on the layer number and not only the model height.
Thanks a lot,
Happy new year.
