Sun Feb 11, 2018 7:47 am
The distance between support and model can only be set by the number of layers.
I hope to be able to set by distance(mm).
When printing with a 0.4 mm nozzle, the proper distance between the modeled object and the support is about 0.12 mm.
However, when the PrimaryLayerHeight is 0.1 mm, the support strongly sticks to the
printed matter at Separation Layers = 1.
I am using the VariableSettingWizard to solve this problem.
By changing the PrimaryLayerHeight of the Contact surface between the model and the support, an appropriate separation width is obtained, and the quality of the model is improved.
I would like an option to automate these settings.
The PrimaryLayerHeight of the contact surface part of the model and the support is automatically changed to the specified value (mm).
