i'm quite experiences with 3d printing. I worked a lot with Slic3r, Skeinforge, Cura, Kisslicer etc. in the past. I used S3D for a while now but the process handling still confuses me. Maybe i'm just doing things wrong so i thought i'll ask.
I do use Multiple printers with several different Filament types from different manufacturers. First of all i'm unsure what gets saved in the Material, Quality and Printer configuration. I want to be able to easily choose material settings whenever i start a print and be able to setup my values quickly without having to reset single values each time. Unfortunately somet hing like Filament diameter seems not to be tied to Material settings. Why is that? Filament sometimes is 1.73mm and sometimes it's 1.81 - very much depending on manufacturer and type.
It would be interesting to have an overview or any UI logic that tells what setting is saved with what type of auto configuration value.
Also Speed: Is there really noe correlation for Speed to Material or quality? This would be awful as of course you have to print flex filaments way slower than any other. Or probably you want to go slow for a high quality print instead of driving full speed.
Apart from that i'm very happy with S3D but the UI logic for processes and the confusion it brings confuses me a lot.
Thanks for helping,
Frank
