Not with S3D.
Can you share the S3D and Slicer profiles ?mr.sneezy wrote: ↑Wed Oct 03, 2018 7:41 pm For info.
I'm mainly now using poly carbonate filament (PC) with this printer now and getting quite good results.
I've tweaked settings quite a lot to get good strength and still have good detail on small features.
I found the biggest improvement was to run the extruder fan full time, at 50%. I thought that would negatively effect layer bond strength, but it does not seem to in this printer with it's heated chamber. I've been using 65C on the chamber heating fro PC.
For features requiring 'bridging' I've had the fan at 90% and slowed the print speed down to about 20mm/S to get good strand reliability.
However I'm still finding that Slicer does better bridging than S3D (I compare both regularly).
Does that wait for the printer chamber to come up to the chamber temp set point, or just set the temp and go straight to heating the bed without waiting ?
