I have a model that includes a rectangular outline with an elevated lip that goes around the entire thing. It's not very wide, and most of it will be done as a series of perimeter runs going around & around. I will need supports, and I'd like the zig-zag of the supports to run perpendicular to the perimeter to get the best support.
My understanding is that you can only specify a global angle for supports, so if I make them perpendicular on two sides, the supports will be parallel on the other two sides, and I will get lots of sagging filament problems. I seem to recall questions about the (un)availability of radial supports for circular objects, which is probably an even worse scenario.
The best I think I can do is to put the supports at 45 degrees, but I figured I'd check with the experts and see if there is some trick I'm missing.
Thanks!
