When is simplify3D 64 bit on macOS?
Posted: Fri Aug 10, 2018 5:33 am
by roncromberge
Hello,
After a long period of inactivity, I installed Simplyfy3D again on my MacBook Pro
And I got the 64bit warning that the app is not future proof.
When can we MacOS users expect a updated version?
Ron Cromberge
Re: When is simplify3D 64 bit on macOS?
Posted: Fri Aug 10, 2018 12:44 pm
by S3D-Jason
Hi Ron,
Simplify3D is actually already a full 64-bit application. The reason you are seeing that warning is that we use a 32-bit installer which allows us to provide compatibility for older systems. You shouldn't see the warning again when using the software, it only shows when you run the installer.
For reference, you can also verify that Simplify3D is a full 64-bit application on your own by following these instructions. Open the System Information application on your Mac, go to Software > Applications, and then click on Simplify3D in the list to the right. It will say:
Simplify3D:
Version: 4.0.1
Kind: Intel
64-Bit (Intel): Yes
