Oozze Shield and Prime Tower Height
Posted: Tue Aug 21, 2018 5:13 am
by smoki3
Hi everybody,
after more than an hour of searching I have not found the feature which is anounced with S3D 4.0:
Where i can find this feature to limit the height of the ooze shield and prime tower?
Kind regards
Kevin
Re: Oozze Shield and Prime Tower Height
Posted: Tue Aug 21, 2018 2:01 pm
by S3D-Chris
Hello Smoki3,
Welcome to the Simplify3D forum! To limit the height of your Prime Pillar or Ooze Shield you simply use multiple processes. Use the Variable Settings Wizard (found in the Tools drop down menu) to create a second process with the height set to where you would like the Prime Pillar or Ooze Shield to stop printing. Then edit your second process to turn off that feature.
