Blobs and zits finially gone, woohoo
Posted: Fri Sep 14, 2018 2:00 am
Thought I would share my experience as I've seen a bunch of blobs and zits threads lately and none really touched on the one thing that finally got rid of my tiny blobs. A combination of retraction, coast, XY speed cut down my blobs big time but I couldn't get rid of them completely. Wipes just seemed to smear and make the blobs longer ( I have it turned off completely and I don't have stringing). I was able to eliminate the stringing moving my XY axis movement speed up to 100mm/s. I started messing with extra restart distance and didn't notice a difference. I started changing EVERYTHING and noticed it getting worse and better but not gone. Finally I figured out that the "Extra restart distance" needed to be a negative number. When I slowed down the print speed I could actually see the nozzle pause to add more filament before it started moving the hot end. Once I put in a negative number in the blobs and zits are gone. I do not see them at all. I finally settled on a -0.2 and everything looks great. My tips are to slow down the print speed and really watch to see WHEN and what is happening. At full speed I was guessing and making it worse. Also the negative number on the extra start distance will allow the hot end to move(and use the ooze to say) before it starts extruding. What I noticed is that when I would start a new layer it would extrude a little before(or as) it started to move and would make a blob.
