new here. need to rotate
Posted: Sun Jun 08, 2014 1:30 am
by imsmooth
I just loaded my box STL into the program. It puts the "bottom" on the top. I have used the mouse to spin the box around. How do I get the top and bottom to flip? In other words, how do I rotate the other axis?
Re: new here. need to rotate
Posted: Sun Jun 08, 2014 10:45 am
by TenKOhms
You can double click on the item and through the window that pops up (you can move it to the side if you want to see the model on the build platform) try adjusting either the X or Y rotation by 180 degrees and you should get a live preview of the rotational effect.
Posted: Mon Jun 09, 2014 3:18 am
by ta1dr
After "drop the table"
Posted: Fri Nov 27, 2015 11:50 am
by RomeFallsAgain
When I did this, my model ended up underneath the grid.
I suspect "Drop The Table" has something to do with it.
So how do you "Drop The Table" ?
Answer in Version 3.0......
Use the Center And Arrange button
Posted: Fri Nov 27, 2015 4:51 pm
by KiLLiN-TiMe
I have to rotate my files often in order to print how I would like to minimize supports and such.
Rotate it like they told you but then press "Edit" at the top of the screen and choose "Center and Arrange Models".
The wording my not be exact, I'm at work so I can't look, but it's something close to that.
That will drop the part on the bed and keep the orientation you picked. If you have more than one part it will arrange them so they fit on the print bed.
HTH,
KT
Got home and I was close enough you should get it. By the way "Ctrl + R" will do the same thing.
Posted: Mon Nov 30, 2015 8:57 pm
by danielhenley
The easiest method is to press ctrl-L and chose a face on the model that you want to be flat on the build platform.
Posted: Mon Nov 30, 2015 11:43 pm
by erniehatt
danielhenley wrote:The easiest method is to press ctrl-L and chose a face on the model that you want to be flat on the build platform.
Thanks for that little gem, I always go to netfabb, this is so much easier.
Posted: Mon Apr 03, 2017 11:54 am
by amarand
Thank you!! Although it would be nice to know how to do this by other means, the CTRL-L worked perfectly for what I wanted to do!
Posted: Wed Apr 05, 2017 6:00 am
by Leeway
I think edit, Place surface on the bed is what I use most. Just click on the surface you want on the bed. You can then manipulate from there for the orientation.
