I'm running Horizontal Size Compensation (-0.4mm) to help with bottom flaring and have noticed a lot of very small sections being laid down that are prone to not sticking. Can anyone think of a way to help with these features?
I do a raft but as just one solid layer. Not in front of S3D right now to relay the settings I have used though.
Basically you are just adding a layer for the small areas to better adhere to.
Rather than a Raft which sucks a lot of print time and plastic I use a brim. On the additions tab set the Skirt layer to 1, Skirt offset to 0 and outline to 6 or 8 The ring of plastic will be attached to the first layer of the part and will need to be trimmed off but will keep the part stuck to the plate.
