G30 or global gcode offset tab ?
Posted: Tue Nov 06, 2018 9:57 am
by Zam
Hello, a simple question here : Is it the same to write G30 Z1.5 in the script tab than putting z=1.5 in the Gcode tab (global Gcode offsets) ?
Re: G30 or global gcode offset tab ?
Posted: Mon Dec 03, 2018 5:12 pm
by S3D-Chris
No, the G30 command is used to help calculate the leveling plane on most modern firmwares. The Gcode offsets in S3D will not be calculated against a custom plane as would be the result of using several G30 commands across you bed.
