Am I following the correct process
Posted: Tue Nov 13, 2018 11:33 am
Hello,
I am checking to see if I am following the most optimized process for using S3D. It seems that for certain types of objects in factory files I do a lot of manual setup that I don't feel is correct. Either I am doing it wrong or I need to file a feature request.
I have been printing out planes and such from 3DLabPrint . These thin wall prints can only be slices using S3D so I bought it and have been able to print many things successfully, but it seems like I do a lot of manual work. Here is what I do.
I have a profile for my Prusa Mk3 printer. I load up the factory files of the objects that are provided, and write down the settings for perimeters, layer heights, and start / stop printing heights.
I then select my printer profile, which of course loads all my G-code, and scripts, but overwrites all of the printing settings (Why it does this is beyond me, not like the number of perimeters in an object should depend on my printing profile but whatever) i then manually re-enter the settings like layers, number of perimeters, etc.
Is there a more optimized path to printing factory file objects?
Thanks in advance,
Mike
Thanks in advance,
Mike
