BoltPro
Merging two separate STLs
Mon Jan 07, 2019 1:38 pm
Hello,
I need to merge/group two STL files into one another however, I need both files to be printed even if they are submerged into another. Currently, both files are being printed as the outline premier with only the infill (ignoring the submerging section of the one STL). I am not sure if there are setting that would allow this.
Thanks for your help,
Re: Merging two separate STLs
Mon Jan 07, 2019 5:33 pm
You mean this?
or this
and you want to have this?
than you must create a 2nd process and select the objects one to each process.
H.
BoltPro
Wed Jan 09, 2019 11:57 am
Thank you so much! That is exactly what I needed.
